Uptime and get-device-config on login
PeterUK
    edited June 2024
    happened again
  • kruess
    kruess Posts: 20 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    edited June 2024
    Same behaviour here on a 100H with Error code 20001, 20002 or 20003.
    Prior to this, we tried to disable some expired security services and got an "invalid version" error when trying to save the simplest config change on the respective service. Maybe it's related with the 'get-device-config' error, maybe not…
    Still "H" series is a short for "Headache"!!! 😬
  • kruess
    Only a reboot, initiated through SSH was fixing this behaviour.
  • kruess
    Still happens with firmware 1.20-2… 😬
  • kruess
    And again a hanging Web GUI on 100H. The error code seems to count +1 for each login attempt (20001, then 20002, etc).
    This early "H" series launch is killing Zyxel reputation quickly… 💩
