WAX620D controlled by USG40 - possible?
Hello
I am having a hard time registering a WAX620D on a USG40 as controller. The USG40 sees the WX620D and I can add it to the controlled group.
However, the icon stays gray and I cannot manage the accesspoint.
Any ideas?
—Thomas
Hi @SpaceCowboy,
The APC version of USG 40's latest firmware(V4.73(AALA.1)C0) is APC3.60. In this APC version, the firewall only supports these AP models:
NWA3160-N, NWA3550-N, NWA3560-N, NWA5160N, NWA5550-N, NWA5560-N, NWA5121-NI, NWA5123-NI, NWA5121-N, NWA5301-NJ, NWA5123-AC, WAC5302D-S, WAC6103D-I, WAC6502D-E, WAC6502D-S, WAC6503D-S, WAC6553D-E, WAC6552D-S, NWA5123-AC-HD, WAC6303D-S, WAX650S, WAX510D, WAX610D, WAC500, WAC500H, WAC5302D-Sv2
You may reference the datasheet:
https://download.zyxel.com/USG40/firmware/USG40_4.73(AALA.1)C0_2.pdf
In addition, USG 40 is an end-of-life model. If you want the WAX620D controlled by a firewall, you may consider migrating to USG FLEX 100.
Zyxel Melen0
It is only supported on newer USG models not sure if thats just the firmware update only.
when you add AP to USG you manage it by USG
Have you allowed from LAN to zywall UDP ports 2018, 5246
Hi @SpaceCowboy,
Zyxel Melen0 -
Thank you for your help!
I will suggest to upgrade the firewall
—Thomas
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
