WAX620D controlled by USG40 - possible?
SpaceCowboy
SpaceCowboy Posts: 8 image  Freshman Member
edited June 2024 in Security
Hello
I am having a hard time registering a WAX620D on a USG40 as controller. The USG40 sees the WX620D and I can add it to the controlled group.
However, the icon stays gray and I cannot manage the accesspoint.
Any ideas?
—Thomas
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,676 image  Zyxel Employee
    Hi @SpaceCowboy,
    The APC version of USG 40's latest firmware(V4.73(AALA.1)C0) is APC3.60. In this APC version, the firewall only supports these AP models:
    NWA3160-N, NWA3550-N, NWA3560-N, NWA5160N, NWA5550-N, NWA5560-N, NWA5121-NI, NWA5123-NI, NWA5121-N, NWA5301-NJ, NWA5123-AC, WAC5302D-S, WAC6103D-I, WAC6502D-E, WAC6502D-S, WAC6503D-S, WAC6553D-E, WAC6552D-S, NWA5123-AC-HD, WAC6303D-S, WAX650S, WAX510D, WAX610D, WAC500, WAC500H, WAC5302D-Sv2
    You may reference the datasheet:
    https://download.zyxel.com/USG40/firmware/USG40_4.73(AALA.1)C0_2.pdf
    In addition, USG 40 is an end-of-life model. If you want the WAX620D controlled by a firewall, you may consider migrating to USG FLEX 100.
    https://webservice.zyxel.com/end-of-life
    Zyxel Melen
    PeterUK Posts: 4,448 image  Guru Member
    edited June 2024
    It is only supported on newer USG models not sure if thats just the firmware update only.
    when you add AP to USG you manage it by USG
    Have you allowed from LAN to zywall UDP ports 2018, 5246
  • Zyxel_Melen
    Hi @SpaceCowboy,
    Zyxel Melen
  • SpaceCowboy
    Thank you for your help!
    I will suggest to upgrade the firewall
    —Thomas
