VMG3625-T50B as repeater / extender / MPro Mesh
I have Huawel 5G H122-273 modem for internet connection.
I want to use VMG3625-T50B as repeater / extender.
Is it possible to configure so that VMG3625-T50B connected to Huawel 5G H112-273 wirelessly
Or Is it possible use MPro Mesh so VMG3625-T50B configure itself automatically
Regards,
Aanamika
You can try to connect VMG3625-T50B to Huawei 5G H112-273 via LAN and let VMG3625-T50B obtain the IP from Huawei. But I don't think these two devices can be MESH.
Looking at the specifications for VMG3625-T50B at https://www.zyxel.com/uk/en-gb/products/dsl-cpe/dual-band-wireless-ac-n-vdsl2-gigabit-gateway-vmg3625-t50b/specifications I do not think that the VMG3625-T50B can act as a WiFi Repeater or Extender…HOWEVER…
But the user guide at https://download.zyxel.com/VMG3625-T50B/user_guide/VMG3625-T50B_2.pdf suggests in Table 1 that it might be possible.
The user guide says that with non-MPro Mesh Router that the set-up can only be Wired, see below extract:
Kind regards,
Tony
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
