Smart mesh went bananas
saltet
saltet Posts: 75 image  Ally Member
my new smartmesh with three Nwe130 BE went offline this morning. The ap;s was installed and running a week a go and all went well. The root ap is connected to Zyxel 5101. The root ap is still green but the other two are red indicated.
Looking at the log something is happening. ?
Why is the smartmesh offline.
You Zyxel team have access to my account.
can you please give mean advice.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @saltet,
    After checking, we found that your APs crashed many times. That is why the smart mesh was offline.
    In addition, since your APs have been upgraded to the latest firmware which fixes the crash issue, they are working well after 6/20. Please help to check if the issue happens again. Thanks in advance.
    Zyxel Melen
  • Zyxel_Melen
    Hi @saltet,
    Thanks for the privilege. We are checking on it and I will update you once I have further information.
    Zyxel Melen
  • saltet
    Looking forward to hear from you.
    my account is.
    tomas.salzmann@telia.com
    To solve my immediate problem I restarted the ap,s but the question is why did the ap go bananas.
  • Zyxel_Melen
    Hi @saltet,
    Zyxel Melen
  • saltet
    Thanks a lot for your answer. That explain why my ap went off line.
    since the upgrade -which I was unknown about - they have been working fine.
    Best regards
