NWA90AX kick wifi client?
NWA90AX is managed by NEBULA, but in Clients page, I can't found kick wifi client button or any function.
how to kick wifi client from NEBULA or via ssh cli ?
example:
samebody use captive portal auth success, then client can always connect wifi, if the client cause trouble, I maybe to see my boss.
Hi @sirocawa
You can block specific client access to your WiFi by setting up a policy rule in Nebula Control Center (NCC). Follow these steps:
- Go to Site-wide > Client > Client list.
- Choose Access point clients.
- Set up the policy rule to block the desired client.
For more detailed guidance, please refer to this article:
Additionally, to enhance your network security, consider deploying VLANs to separate network traffic, isolating specific segments from the rest of your network. Moreover, to prevent devices from communicating with each other within a particular SSID, you can enable the Guest Networks feature on the SSID.
Here is an article about setting up a Guest Network Wi-Fi on Nebula Control Center:
Kay
Hi @sirocawa
Kay
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
