Able to establish SSL VPN connection but computer firewall ignores traffic
yitbp_Luis
Via SecureExtender I am able to connect from a remote computer to the USG20 router at my office. When trying to connect to file server the file server firewall blocks it. If I disable firewall connection to file server is obtained. System was working before but Windows 7 Jan update had issues with remote access.
I would like to setup a rule on firewall to allow traffic on port 443. Is that the port that USG20 uses to send SSL VPN traffic?
Firewall is Windows Firewall running on file server
Try to create the security policy to allow traffic from tunnel t local server.
Go to security policy> From: Tunnel, To: any, Source:any, Destination: Server IP, server: any, allow0 -
Create a security policy FROM TUNNEL to ZyWall,When you installed your Zyxel you delete de default rules?0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
