SCR50AXE and mesh wifi
Good morning everyone,
during these days we are testing new firmware on SCR50AXE, it seems stable and very nice. I'm just looking for some improvements, for future Companies, like Mesh WiFi on this security router.
Anyone has experience on that?
I'm deploying this router with satisfaction but in some environments it needs more WiFi coverage with limited possibility to plug an AP via LAN cable to the router. So it would be great to have the choice to buy Zyxel APs (like the NWA50AX or the 90AX) and to link them to the router using the Mesh feature instead of AP mode.
Any tip & tricks are welcome.
Hi @GiuseppeR
Thank you for reaching out to us with your valuable feedback.The SCR 50AXE model will not include the MESH feature. For extending WiFi service, an Ethernet connection will still be required.
However, we have a plan to add mesh system in future products.
If you have any further inquiries or suggestions, please feel free to let us know.1 -
Is there a chance to add Mesh feature in a software update? It's the only thing missing in this router and it's hard to understand why...
Hi @Majkel
The USG LITE60AX support the MESH feature.
You can refer to the link below for more information.
So what does the Smart Mesh option visible in the settings do?
By clicking on the list of supported models, the information "All models" appears.
If there is no mesh support, what is the problem of adding it with the next firmware update?This is probably not a hardware problem, so what ?
It is difficult to understand why this model lacks such an important function.
Hi @Majkel
Thanks for the feedback.
The page displays a greyed-out icon of the Smart MESH and along with a hint listing supported models.For more information, you can refer to the function table
On my SCR50AXE it is disabled by default, but I can turn it on without any problem and that's why I'm asking.
Hi @Majkel
The smart MESH settings here are for the Access points.The information will only list the Nebula APs model on this page.
- 3K Nebula
- 222 Nebula Ideas
- 620 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
