signal strength not showing up
Wookie
Wookie Posts: 52  Ally Member
Hi there
I use Nebula to configure my wifi-environment where there are 4 APs. Recently I noticed that the signal strength of some (but not all) clients connected to the AP called AP-Stube are not showing up. clients connected to the other APs are showing the signal strength.
could you please have a look at my site (Dietikon, Org Graf) ? I restarted the AP-Stube several times and also could not find any solution in the community.
Bildschirmfoto 2024-06-13 um 08.15.24.png Bildschirmfoto 2024-06-13 um 08.14.56.png Bildschirmfoto 2024-06-13 um 08.15.07.png
Many thanks for your support
Kind regards
Andrew
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,810  Guru Member
    Hi @Wookie,
    After checking, we would like to exclude this issue from being related to AP. Could you help to reboot your AP "AP-stube"?
    Zyxel Melen
  • Zyxel_Melen
    Hi @Wookie,
    Thanks for the privilege.
    I have checked the AP-Stube's current stations and it displays the lacking information like signal strength, client channel, etc. But somehow the AP client page did not display.
    We are checking on it and I will update you once I get further information.
    Zyxel Melen
  • Wookie
    thats great, thanks a lot.
  • Zyxel_Melen
    Hi @Wookie,
    Zyxel Melen
  • Wookie
    strange, I actually restarted AP-Stube several times and now the issue seems to be gone. thanks for your support
Nebula Tips & Tricks
