delete Static MAC-address on XS-1930
Antivilf
Antivilf Posts: 2
in MAC Table i have two Static records
one for CPU and one for DHCP server
but in "Static MAC Forwarding" i have no created rules for that DHCP MAC
how can i delete it and how it may be created without Forwarding ?
Firmware Version
V4.60(ABQF.1) | 05/11/2020
Hardware Version
V1.2
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,631 image  Zyxel Employee
    Hi @Antivilf,
    You might click the transfer button on the MAC table page. This button will transfer the dynamic MAC address by the type you choose.
    Please navigate to Menu > Advanced application > Static MAC forwarding page. Select the MAC and click the delete button to remove it.
    Zyxel Melen
  • Antivilf
    Antivilf Posts: 2
    as i said, i have no records on Static MAC forwarding page at all
  • Zyxel_Melen
    edited November 2024 Answer ✓
    Hi @Antivilf,
    Since your XS1930 is using a very old firmware version, please upgrade to the latest firmware first. This issue was fixed on the previous firmware.
    After that, please help to collect the information below for us to check if the DHCP server's MAC is still static:
    Thanks in advance.
    Zyxel Melen
