delete Static MAC-address on XS-1930
Hi @Antivilf,
Since your XS1930 is using a very old firmware version, please upgrade to the latest firmware first. This issue was fixed on the previous firmware.
After that, please help to collect the information below for us to check if the DHCP server's MAC is still static:
- The MAC table screenshot.
- The Static MAC forwarding page screenshot.
- The switch tech support.
Thanks in advance.
Zyxel Melen0
Hi @Antivilf,
You might click the transfer button on the MAC table page. This button will transfer the dynamic MAC address by the type you choose.
Please navigate to Menu > Advanced application > Static MAC forwarding page. Select the MAC and click the delete button to remove it.
Zyxel Melen0 -
as i said, i have no records on Static MAC forwarding page at all
Hi @Antivilf,
Thanks in advance.
Zyxel Melen0
- 217 Nebula Ideas
- 577 USG FLEX H Series
- 297 Service & License
- 474 News and Release
