[NEBULA] Is PoE scheduling handled by NSW?
WaYne
WaYne Posts: 12 image  Freshman Member
First Answer First Comment Friend Collector First Anniversary
edited April 2021 in Nebula
Hi all,
another question, I have PoE schedule configured, but I noticed that if my uplink is not connected the schedules won't work.
Shouldn't the schedule be done by the switch or is it not?
Wayne
  • BackZero
    BackZero Posts: 17 image  Freshman Member
    Hey WaYne, your question seems not clear to me. What did you mean "my uplink is not connected" ? Could you be more specific ?
  • Iwannaquitthegym
    Iwannaquitthegym Posts: 23 image  Freshman Member
    Not pretty sure but might be that this process is handled by the cloud.
    Maybe someone could confirm it, cc: @Nebula_Dean @Nebula_Bayardo @Nebula_James @Nebula_Charming @Nebula_Irene
  • WaYne
    Okay it is clear now, much appreciated thanks.
  • FrankIversen
    FrankIversen Posts: 92 image  Ally Member
    Ideas master First Comment Friend Collector Third Anniversary
    Settings should be cached to the device, so it would perform 100% of functions regarding of internet connectivity.
    This is a feature request :)
    Will an AP keep the ssid and security locally etc. if the Internet is not available?
  • WebberIT
    WebberIT Posts: 53 image  Ally Member
    Ideas master First Comment Friend Collector Second Anniversary
    @FrankIversen
    Yeap, it does keep SSID and security configs, except if ur using cloud-auth then it depends on your NCAS configurations.
Nebula Tips & Tricks
