Firmware updated but unable to login
124»
  • bulldog715
    bulldog715 Posts: 29
    image  Freshman Member
    What you talk about? Is?
  • bulldog715
    Microsoft Windows [Version 10.0.22631.3810]
    (c) Microsoft Corporation. All rights reserved.
    C:\Users\pc>ftp 192.168.1.1
    Connected to 192.168.1.1.
    220---------- Welcome to Pure-FTPd [privsep] ----------
    220-You are user number 1 of 50 allowed.
    220-Local time is now 00:48. Server port: 21.
    220-IPv6 connections are also welcome on this server.
    220 You will be disconnected after 15 minutes of inactivity.
    504 Unknown command
    User (192.168.1.1:(none)): admin
    331 User admin OK. Password required
    Password:
    230 OK. Current restricted directory is /
    ftp> Is
    Invalid command.
    ftp> bin
    200 TYPE is now 8-bit binary
    ftp> Is
    Invalid command.
    ftp> put C:\V517ABMT6C0.bin
    200 PORT command successful
    553 Can't open that file: Permission denied
  • Peter2
    Peter2 Posts: 179
    image  Master Member
    "ls" small L and s , this gives directory information and shows if the data connection is functioning with my router .
    As a test i deactivated the firewall for the local zone in Win 10 .
    So it was a little step forward but not the complete success …
  • bulldog715
    220-You are user number 2 of 50 allowed.
    220-Local time is now 01:02. Server port: 21.
    504 Unknown command
    Password:
    ftp> ls
    150 Connecting to port 8329
    data
    fw
    zcfg_config.json
    226 3 matches total
    ftp: 31 bytes received in 0.00Seconds 31000.00Kbytes/sec.
    ftp> bin
    ftp>
  • bulldog715
    Oh my god......my god......I finally FIXED it!!!!!
    Windows CMD - FAILED! 553 Can't open that file: Permission denied
    Linux Terminal - FAILED! 553 Can't open that file: Permission denied
    FireZilla - FAILED! 553 Can't open that file: Permission denied
    WinSCP - FIXED!!!!! Uploaded latest firmware and factory resetted and now finally logged in via Web
    I AM SO HAPPY NOW!   😁😁
  • Peter2
    Peter2 Posts: 179
    image  Master Member
    wow this is ok now - i am relieved too !
  • bulldog715
    edited July 2024 Answer ✓
    Instructions: download WinSCP here: https://winscp.net/eng/download.php
    Install WinSCP and login like this below
    when logged in, choose firmware latest version from desktop on the left side (PC) and now click fw folder on the right side (router) and click upload firmware to the router and check the router for red flashing light and wait until it all completed, then closed WinSCP and go to website 192.168.1.1 and enter username and password (from your router label) as you will be able to logged in and see all factory resetted because the router will ask you to choose new password to change the login.
    Hope this will help other if they get struggling with 553 Can't open that file: Permission denied
    Thanks Tony & Peter for trying to help me. Yes, I am relief all ok now. Broadband is now working on my router.
