XGS1930 2.5 Gbit/s with SFP+ RJ45 Modul possible?
Tzunami
Tzunami Posts: 26  Freshman Member
XGS1930
Is it possible to connect a 2.5 Gbit/s client to one of the SFP+ ports (with a RJ45 10 Gbit/s Modul) and get the full 2.5 Gbit/s, or are only 1 Gbit/s and 10 Gbit/s possible?
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    edited July 2024 Answer ✓
    Hi @Tzunami ,
    We have tested your case on our site, and the results confirm that it is possible to connect a 2.5 Gbit/s client to one of the SFP+ ports using an RJ45 10 Gbit/s module, our SFP10G-T, and achieve the full 2.5 Gbit/s speed.
    However, based on typical usage scenarios and specifications, we recommend using the SFP+ module for uplink to use its 10G capability.
    FYI: Please note that the XGS1930 web GUI will display 10Gbps - the data link speed between XGS1930 and SFP10G-T.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Tzunami ,
    You can find the minimum power consumption for the XGS1930 series in the datasheet. For instance, the minimum power consumption for the XGS1930-28 is 12.4 watts. You can refer to the datasheet here:
    https://download.zyxel.com/XGS1930-28HP/datasheet/XGS1930-28HP_6.pdf
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Tzunami ,
    Zyxel_Judy
    Untitled Image
  • Tzunami
    I have a second question.
    What is the min. power consumption when simply running the XGS1930 (no connections, no SFP+ Modules)? I only found the max. power consumption of 24.6 Watt.
  • Zyxel_Judy
    Hi @Tzunami ,
    Zyxel_Judy
    Untitled Image
  • Tzunami
    Thx, I have read an older datasheet without this data ;)
