How to port forwarding on an USG LITE 60AX
I want to replace my current router with then router 'USG LITE 60AX', but then I need to be able to forward ports coming in to different internal IP addresses and ports.
For example, port 25 needs to be forwarded to a mail-server en port 80/443 to a web-server.
It can also be that I get traffic coming in on port x should be re-directed to port y with specific IP address.
Hi @jjvalstar
The USG LITE 60AX security router supports NAT (Network Address Translation) features. You can refer to this article to set up the NAT rule:
Kay
Hi @jjvalstar
Kay
- 441 Beta Program
- 529 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
