How to configure LDAPS on ATP700 firewall?
I have two ATP700 firewalls in high availability mode, not managed by Nebula. I would like to know how to enable LDAPS so that AD users can authenticate through it. Before enabling LDAPS, it worked with simple LDAP on port 389. After enabling LDAPS, I changed the port to 636 and enabled "use SSL," but it does not work. When I run the test, I get the message: "Wrong Bind DN or Password."
Tkanks,
I found the origin of my problem it was the DN it was necessary to put the complete and precise DN.
Thank you for your help
Hi @Jeanbaptiste ,
Some LDAPS servers verify the client certificate, with the firewall acting as the client in this scenario. If your server verifies the client certificate, please exclude the firewall from this verification.
If the issue persists, please capture packets during your LDAPS testing and share them with us. We will review the negotiation process and inform you of any findings.
Zyxel_Judy
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
