Speedtest via VMG3625 Home router
Hi All, I can access the home router (VMG3625-T50B) via ssh as root. I want to test with /bin/speedtest but I get an error. How can I do that? It probably doesn't work like speedtest-cli, but can you share a command I can try?
Hello @tancetin ,
Welcome to the forum.
According to https://download.zyxel.com/VMG3625-T50B/user_guide/VMG3625-T50B_2.pdf the VMG3625-T50B does not have a built in speed test, see below extract.
This means that you will need to do speed test from a Host connected to your VMG3625-T50B.
Kind regards,
Tony
Hello @tancetin ,
Kind regards,
Tony
Thank you @tonygibbs16 .
King regards.
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
