[NEBULA] MAC-based Authentication with Nebula Cloud Authentication
Jules
Jules Posts: 6 image  Freshman Member
edited April 2021 in Nebula
I could not find a guide on how to setup MAC-based Authentication for our Wireless Access Points.
It looks like I should be able to set this up so devices should automatically connect to the Wi-Fi if I have added the MAC address to the cloud authentication in the organization?
Please can you let me know if you have a guide for setting this up?
Many thanks,
Jules
  • Jules
    Thanks Barney.
    After trying a few different setups, I can see how it works now.  Only the authorised MAC addresses are allowed access.  Even if the device has the WPA2 Pre-shared key, it can only connect if the MAC address is on the list.
  • Zyxel_Barney
    Zyxel_Barney Posts: 85 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    edited February 2019
    Guide for MAC-based Authentication for Wireless Network has been posted in the FAQ section.
Nebula Tips & Tricks
