USG FELEX 500H, Request failed with status code 500
Device update does not work!
The update does not work through Nebula! Even though I bought the license, nothing changed!
Hi @matef & @gyfdjuysdg,
This issue was due to the certificate service issue and it is fixed now. Please help to clarify if you still have the error code.
Zyxel Melen0
Hi @matef,
Could you help set the Global Zone Forwarder with 8.8.8.8 or 1.1.1.1 and refresh the registration status first?
If still have error 500, please help to collect the diagnostic file for us to check. Thanks in advance.
Zyxel Melen0 -
I have the same problem
it looks like a lot of people have the same problem
Zyxel Melen0 -
I have the same issue just now.
My device is USG FLEX 100H.
I registered my device at NCC.
Global zone forwarder is set with 1.1.1.1 and 8.8.8.8.
Internet connection OK, I can see NCC via my device.
But following message is shown when Licensing → Licenses → Refresh
"Device Registration Status:Not Registered", "Request failed with status code 500"
Hi @SandB,
Could you provide remote access for me to check? I will send you a message for the request.
Zyxel Melen0 -
Hi, I have this issue too:
I change the Global zone forwarder but nothing happen, could you help me with that?
This devices was working properly until some days ago. Don't know if it was the upgrade of the firewall that it was installed with errors or what happen.
Let me know if you need more information. Thanks!
Hi, I have the same issue, that devices (USG Flex 100H) was working properly until some days ago.
I try to change also the Global Zone forwarder but nothing happen.
Could you help me?
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
- 106 Security Highlight
