No WiFi
Hello, I'm in a rental apartment with a zyxel router, everything was fine, I went on a week long trip and came back yesterday noticing that there was a red light on the router and I couldn't find the WiFi network on my phone or computer. There is internet connection through the Lan cable. I already tried to switch on and off, unplug all the cables, reset to fabric settings and I even go to the inside settings through the 192.168.1.1 and all the WiFi settings are on. I don't understand what's wrong, and the agency of the rental apartment doesn't helped so much, I really need the WiFi connection
  • Zyxel_Kay
    Zyxel_Kay image  Zyxel Employee
    Hi @Takutolady_2
    To assist you better, could you please provide the following information?
    1. What is your router model? Is it the Nebula FWA510 or a different model?
    2. What is your device's current firmware version? If possible, please check for and install any available firmware updates to see if this resolves the issue.
    Kay
  • Hi!
    The model is NR5103E and firmware V1.00(ACDJ.1)b3_D0
  • Bob_C
    Bob_C image  Master Member
    Hi Takutolady_2,
    Does it help if you disable Easymesh controller (Wi-Fi > Easymesh)?
    Or does it help if you disable same settings for 2.4G and 5G (untick the top box on Wi-Fi > General tab) and rename 5G SSID (choose "5GHz" from Band's drop-down list, rename "WiFi Network Name)?
    Regards,
    Bob
