block USG40 every 4-5 days
Good morning,
I find a strange behavior of the firewall USG40, for some months now there are blocks of the apparatus that no longer allow navigation. Even local access to the usg is degraded and the only way to resolve is to do a forced reboot. Currently the firmware V4.33 (AALA.0) is installed but also with the last update the problem has not been solved.
also others have detected the same problem?
Not seeing any problems with my USG40 on V4.33
Do you use any of USG UTM profiles?
connected in wan via an external modem, when the blocking happens I just have to restart the USG, the connectivity part works regularly on the connected modem.
the problem is that when it happens I can not even access locally the web panel of the USG40, it also blocks the management on the local IP address.0
@cantonim
Regarding to this case,We may need the config file and some other information to dig out further. I will private message you for more details.
Charlie0
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
