HA and LAG on LAN interfaces
Yes, LAG + HA Pro can fulfill.
If Switch A & B support stacking (as a virtual switch), you can set LAG interface mode to 802.3ad(LACP).
Otherwise, set LAG interface mode to active-backup or balance-alb
Be aware, not all model support LAG interface.
As I know, USG310/1100/1900 support it.
Hi zyman2008,Thanks for your reply.There is a mistake on my dia, the switch A on the right side (WAN) is switch C... sorry.Switch A and B don't support stacking unfortunately so active-backup mode was my first guest, thanks to confirm it
About the LAG support, I have 2 USG310 so all good.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
