Does the USG Lite 60AX support packet capture (via NCC) to use e. g. Wireshark
Hi @Lohkamp
The USG LITE 60AX does not support packet capture on Nebula CC or through its local web configurator. Currently, this feature is not available for this specific model.
If you need packet capture functionality, you might need to consider alternative methods such as using a network tap or a mirrored port on a switch to capture traffic with tools like Wireshark.
Kay
Hi @Lohkamp
Kay
Thank you for your quick and precise response, Kay.
Kind regards
Oliver1
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
