[Release Note] NWA130BE - V6.75 Patch 0 firmware has been released
Hi @Chris888
The NWA130BE will support the MLO feature starting from firmware version V7.00, which is scheduled for release by the end of July.
If your access point is in Nebula cloud mode, you will be able to upgrade your firmware following the Nebula Control Center upgrade. The latest firmware V7.00 will be available alongside the upcoming Nebula Control Center upgrade in mid-July.
Stay tuned to our and for the latest updates.
Kay
💪 looking forward! Thanks!
I upgraded to 7.00, which was released today. I can't seem to find the MLO option. Is MLO only available in Cloud mode?0 -
Hi @jakeman2048,
Yes, this MLO function is only could be configured in Nebula Cloud mode, starting from Nebula 18.10, launched on July 15 at 01:00 (UTC+0). Please check the SSID advanced settings page.
For more details about the new NWA130BE V7.00 firmware release, please refer to this document:
https://download.zyxel.com/NWA130BE/firmware/NWA130BE_7.00(ACIL.1)C0_2.pdf
Zyxel Melen1 -
@Zyxel_Melen
Is there a plan to make MLO available in standalone mode?0 -
Hi @jakeman2048,
Let me help to check if we have a schedule now. By the way, would you like to share your WiFi 7 AP model?
Zyxel Melen0 -
NWA130BE
Also, I tried the MLO with cloud and all my non-802.11be clients stopped working.
Hi @jakeman2048,
Could you share the models of your devices? And do you mean the client cannot connect to the SSID?
Zyxel Melen0 -
Hi @jakeman2048,
After investigation, only WiFi 6 and above wireless NIC card can connect to the SSID with MLO enabled. This is because the older generation wireless NIC cards cannot read the MLO headers. If your clients' wireless NIC card is not WiFi 6 or above, please create an SSID without MLO for them.
Zyxel Melen1
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
