SecuExtender 4.0.3.0 (windows) not working (VPN connection still ok)
2»
  • Zyxel_Emily
    Hi @Thysmith,
    AD user is able to establish SSL VPN to USG40.
    Make sure ad-users is on the list of selected user in SSL VPN policy.
    If you’re using the default Authentication Method rule, make sure “group ad” is on the list.
    If you create another rule(ex: new_auth) in Authentication Method with “group ad”, remember to select the new created rule (ex: new_auth) in CONFIGURATION > System > WWW > Service Control > Authentication.
  • Thysmith
    Thysmith Posts: 16 image  Freshman Member
    Hi Emily, Looks like my settings were correct and the Firmware update resolved my issue! Thank you so much!
  • Redcorsito
    Redcorsito Posts: 4 image  Freshman Member
    Hello:
    i have the same problem. Please, can you send me the latest version of firmware?
    Thank you!
  • Puoi inviare il new firmware SecuExtender v4.0.4.0 anche tramite DM? Grazie
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Cristian_Bastone,
    Please find the SecuExtender on the Zyxel download library. The link is below:
    Puoi trovare SecuExtender nella libreria di download di Zyxel. Il collegamento è qui sotto:
    Zyxel Melen
