T56 and nwa50AX pro
Goodafternoon.
From Odido I got the zyxel T56 with a 1gb fiber connection. I had a mesh situation from google pods, but i was not satisfied. So I want to have a mesh with 1 pod and there was recommended the nwa50ax pro, also because i wanted to own the pod. But, it is not easy to install,… yes, as a router, that is no problem, that works. But how can I install the system as mesh, so no cable use.
Thanks for your answer.
Greetings
Jan Balfoort
Hi @janusjan,
May I know if you want the zyxel T56, google pods, and nwa50AX pro to build a mesh system?
If that's what you want, I would like to let you know that the mesh technology of zyxel T56 and nwa50AX pro are different. Therefore, you cannot set mesh system between these devices. I'm not sure what mesh technology google pods uses, but probably is not the same.
To make sure you can have a better WiFi signal, it is recommended to build a roaming system, which is setting up the same SSID name and credential on all of your devices.
Hope it helps
Zyxel Melen0
Hi @janusjan,
Hope it helps
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
