ATP 700 NAT didnt forward 1:1 443 and 80 ports
Hi.
ATP 700, 1:1 forwarding to the IP WAN interface on ports 443 and 80 does not work; the ports for the GUI were changed from defaults. The firmware is up to date. Everything is ok with other ports. In the logs ACCESS FORWARD.
Did anyone have this problem?
Yep, i have one WAN ip. Is this a problem? I planned to change subnet WAN from /30 to bigger.
No just checking I test with one WAN IP
your log seem to show a connection to 443 without the NAT happening to port 55443 which is odd
Them ports should forward just fine test to a PC with
scan for ports at GRC
https://www.grc.com/x/ne.dll?bh0bkyd2
package capture on WAN that your seeing the incoming SYN for them ports by 4.79.142.206
1:1 translate on 443 and 80 do not work, but with other pots everything is fine.
Hello @extsa
I wonder if it is worth you checking that your ATP700 is running the latest firmware?
see https://support.zyxel.eu/hc/en-us/articles/360013941859-Security-Products-Firmware-Overview-and-History-Downloads-for-FLEX-ATP-USG-VPN-ZYWALL#h_01HF42Q862DD5T0Y4E7JYG3756 and the below screenshot.
You might be experiencing a bug that has been fixed, or one that has not been fixed.
Kind regards,
Tony
testing here with:
USG FLEX 200
V5.38(ABUI.0)
port 80 forwards to 55580 fine to a test HTTP server
Do you have one WAN IP?
i will try 5.38
Now:
still didnt work..
in logs acces forward:
can any security feature ban port 443 or 80?
Ty guys. The problem was in our LAN.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
