ATP 700 NAT didnt forward 1:1 443 and 80 ports
extsa
extsa Posts: 8  Freshman Member
Hi.
ATP 700, 1:1 forwarding to the IP WAN interface on ports 443 and 80 does not work; the ports for the GUI were changed from defaults. The firmware is up to date. Everything is ok with other ports. In the logs ACCESS FORWARD.
Did anyone have this problem?
    PeterUK Posts: 3,892  Guru Member
    edited July 2024 Answer ✓
    Yep, i have one WAN ip. Is this a problem? I planned to change subnet WAN from /30 to bigger.
    No just checking I test with one WAN IP
    your log seem to show a connection to 443 without the NAT happening to port 55443 which is odd
