DDNS in V1.20 for 2024-04-18 14:10:29 problems
I'm sure DDNS was working fine in V1.20 2024-04-15
So I have three WAN's VLAN443, WAN2 and WAN3 if all three are on line WAN2 tries to DDNS sends a SYN gets a SYN ACK then it RST it but if I remove WAN3 then DDNS for WAN2 works
It will work on a reboot then if you disable/enable the DDNS for WAN2 shows fail until you uplug (or disable the interface) WAN3
Ok I found the link to this problem if you have User-Defined Trunk using least load first Load Balancing Index(es) Outbound + inbound
VLAN443 Active
ge2 WAN2 Active
ge3 WAN3 Active
It stops DDNS on WAN2 from updating when using WRR no problem
Another problem is User custom DDNS only auto works and not Public IP but Public IP will work on a select DDNS like no ip or DynDNS
USG FLEX 200H V1.21(ABWV.0)
Still problem with custom DDNS and Public IP update fails auto is fine
still a problem with least loaded first if used as default truck for DDNS to update by auto or Public IP but interface is fine and is WRR is used DDNS is fine but problem above
- 441 Beta Program
- 293 Service & License
- 461 News and Release
