Switch Zyxel GS1200-5 pinging, but no web ui
Hi!
I'm trying to setup switch to make a 2Gb/s bond, but I cannot access Web UI at all.
Everything else is working.
I can ping 192.168.1.3.
The network with NAS is working, but its slow.
I have IP 192.168.1.10 and 192.168.1.100 for my PC and my NAS
I tried everything, turning off all LAN cables except my PC, turning WIFI on/off, changing IP to 192.168.1.4, resetting the switch. Nothing works 8(
Telnet is not connecting
What can i do? Maybe I can somehow upgrade firmware without web ui?
Hi @firefaced
There might be an IP conflict in your environment. Please try isolating the PC and switch by disconnecting all other devices from the switch.
Then, set your PC to a static IP of 192.168.1.10 and connect it directly to the switch. Try accessing the switch via the IP address 192.168.1.3.
Nami
Hi @firefaced
Is the switch connected to a DHCP server? If so, please check the DHCP table for the switch's IP address.
Nami
No switch is not connected to any server. All IPs are static. It connects PC to NAS.
Web UI worked a while ago, now it's not
Hi @firefaced
Nami
Hi Nami!
I turned off WIFI dongle and Bluetooth dongle, and it worked. Guess one of that things was conflicting with 192.168.1.3
Thank you! 8)
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
