Domain Zone Forwarders not working
nick_patchett
nick_patchett Posts: 12 image  Freshman Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate First Comment Fifth Anniversary
Has anyone use Domain Zone Forwarders on the Flex H range to direct specific requests to different DNS servers?
I have had to open a ticket as it doesnt appear to be working on my FLEX 700H when directing DNS requests for the nhs.uk domain to a DNS server accessible via an IPSEC VPN.
My static routes are in and working as DNS resolution works ok if I statically assign the DNS servers to my laptop.
«1
    PeterUK Posts: 4,264 image  Guru Member
    Did you have this problem with a non H model of USG?
  • nick_patchett
    This is a brand new installation so there has never been any other firewall installed.
    edited July 2024
    I think I have seen this problem before which it can't be done due to you not being able to set Query Via VPN I think I worked out a workaround I see if I can find the post....
    can't find this old post about.
    So this is a site to site VPN?
  • nick_patchett
    Yeah it's an IPSEC VPN and I need to query a DNS server at the other end of a tunnel.
    This is how I've set it up
    You seem to have a VTI setup but I don't see how to set it up I got no add button
  • nick_patchett
    The VTI was created automatically when I created the IPSEC VPN
    I see different to other models so the setup is site to site Route-Based not Policy-Based
    edited July 2024
    SO I finally got it setup with VTI between FLEX200H and USG60W to by Bind server for DNS and it works here.
    Their was I static route that was added but I removed it does not seem to need it
    Is your VTI Setting Local IP setup for your LAN subnet with a IP not in use?
    what is the remote end IP Address Assignment set to for VTI?
  • nick_patchett
    The VTI was all automatically configured by the 700H and is set to a 169 address
