[NEBULA] Whatsapp - round times
paulb
paulb Posts: 16 image  Freshman Member
First Comment Nebula Gratitude First Anniversary
edited April 2021 in Nebula
we are implementing a wireless solution at a school. It turns out that response time for whatsapp-users is pretty high when on wifi, changing to the 4G -network delivers almost immediately. (Takes about a minute to receive/send a message).
Any idea?
Tnx,
Paul
  • CrazyTacos
    CrazyTacos Posts: 53 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Are you connecting to the 2.4G or 5G radio?
    How many APs are in this school?
    Were you able to verify which AP your device is connected to?
    What about the signal strength between AP and station?
    Sometimes you could be standing directly under an AP only to find out you are connected under a different one.
  • paulb
    the problem seems to occur on all AP's...
    We are using a mixture of AP-models (NWA1123-ACv2 and NAP303) over zyxel switches and passing throuhgh a NSG-200 to be uplinked to our "corporate firewall' (Watchguard)
    Working through the Watchguard directly does not give a problem, so it must be something on the Wireless...
    Paul
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @paulb,
    Because we want to know more detail about your environment, I'll PM you for checking.
    Thanks.
  • paulb
    Done some more testing and is seems that it has something to do with the categories for content filtering on the NSG-200.
    I tested and checked the categories for WhatsApp and they were not blocked, so I turned off all of the contentcategories...Result: all of a sudden everything worked perfect!
    I have a feeling that there's something going wrong with the filtering...
  • Zyxel_Freda
    Hi @paulb
    Since there's the other post discussion the same issue in NSG category, let's discuss there.  :)
    https://businessforum.zyxel.com/discussion/comment/6862#Comment_6862
    Thanks.
Nebula Tips & Tricks
