ATP 500 - static ip, "Enable IP/MAC Binding and DHCP Enforcement" option from instandalone mode
AlexandervonW
AlexandervonW Posts: 17 image  Freshman Member
edited July 2024 in Nebula
Hi there,
does anyone know, if the above option, when configuring static ip addresses is available in Nebula?
I would need that option, for blocking unwanted devices on the network having generally access and i also wonder if there is any other way to acomplish this?
Many thanks for help
Alexander
Best Answers
    PeterUK Posts: 4,366 image  Guru Member
    edited July 2024 Answer ✓
    Just a limitation of Neubla (in other words not added yet) where as stand alone has this feature.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @AlexandervonW ,
    Currently, there is no "IP/MAC Binding and DHCP Enforcement" with ATP/USG FLEX on Nebula mode.
    You can use the "Cloud Monitoring Mode" to monitor the APT500 on Nebula and to use "IP/MAC Binding and DHCP Enforcement" on Premise mode as a solution.
    Zyxel_Judy
    Untitled Image
  • AlexandervW
    AlexandervW Posts: 7 image  Freshman Member
    First Answer First Comment Friend Collector Seventh Anniversary
    Hi Zyxel_Judy,
    ok, thanks. I will look into that. For me, this discussion can be closed.
    Have a nice day..
    Alexander
  • Zyxel_Judy
    Hi @AlexandervonW ,
    There is “IP/MAC binding" on the Nebula. To implement that feature, you can follow the steps below:
    • Go to Configure > Firewall > Interface Page
    • Select the relevant interface and click the Edit button.
    • Enable the DHCP server and enter the required information.
    • Click the + Add button for the Static DHCP table.
    • Create entries in the static DHCP table by specifying the IP address and MAC address for each client.
    • Click the OK button.
    Zyxel_Judy
    Untitled Image
  • AlexandervonW
    Hi Zyxel_Judy,
    yes, i know there is IP/MAC binding in Nebula, but is there also "DHCP Enforcement" enabled? Because that means, if i do not use for. ex. a DHCP server on that network, only known MAC addresses can have access to the network?
    Thanks for help
    Alexander
    So have you tried a static IP on the network and it work?
    One way to add DHCP only is a switch with DAI (DHCP Snooping) I think
  • AlexandervonW
    edited July 2024
    Hi PeterUK,
    nice to hear from you again. I used another account with my last problem, the same topic with a new USG FLEX 200H.
    No, i did not try that in Neubla, i thought i ask first. As i wrote in my last comment on the USG FLEX 200H topic, i moved back to a ATP500 and there everything is working as it should. (Even the more than one time admin login problem with uOS in macOS is gone, cool!!!)
    But back to topic, may i ask why nobody is using this feature? Why should i use something on a switch, if the firewall has this working and easy to configure feature?
    best
    Alexander
  • AlexandervonW
    Hi PeterUK,
    I thought so, but now you confirmed. Thank you very much.
    Have a nice day
    Alexander
  • Zyxel_Judy
    Hi @AlexandervonW ,
    Zyxel_Judy
    Untitled Image
  • AlexandervW
    Hi Zyxel_Judy,
    Have a nice day..
    Alexander
Nebula Tips & Tricks
