Assistance with Guest SSID and VLAN Configuration
I am using a Zyxel USG110 and have two Zyxel Access Points (APs) connected directly to the same LAN1 network (ports 4 and 5). The current configuration includes a Wi-Fi network with an SSID that uses the LAN1 IP subnet.
I would like to create an additional guest SSID and assign VLAN10 to it. The intended network setup is as follows:
  • The USG110 provides internet access through the WAN interface.
  • Ports 4 and 5 on the USG110 connect to the APs.
Could you please guide me on how to configure the guest SSID with VLAN10 while ensuring the APs receive the necessary VLAN information from the USG110?
    PeterUK Posts: 3,726  Guru Member
    edited July 2024 Answer ✓
    That would be why its not working you need a VLAN PoE switch to tag the VLAN from USG to AP or just PoE injectors
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,149  Zyxel Employee
    Hi @mike_bt,
    Please reference the handbook of USG110 page 691 "How to create a Wi-Fi VLAN interfaces to separate staff network and Guest network".
    This chapter guides you on how to set up the guest VLAN interface on USG110. For the SSID setting, although the handbook uses controller mode, you can still reference it since the configuration steps are similar to the standalone mode of your access point.
    Hope it helps.
    Zyxel Melen
  • mike_bt
    mike_bt Posts: 8
    Hello and sorry for the late reply.
    I followed all the steps but unfortunately it did not work.
  • Zyxel_Melen
    Hi @mike_bt,
    Could you screenshot the current setting and share it with us? It will help us to clarify the issue. You need to screenshot the Interface > ethernet setting & port setting page information for FW part. And SSID settings for AP part.
    Zyxel Melen
  • mike_bt
    mike_bt Posts: 8
    As per your request.
    edited July 2024
    What AP's do you have? When you say the AP are directly connected ports P6 and P7 on LAN2 just with PoE and no switch?
    Make a zone first
    To make VLAN 10 go the VLAN tab and add with
    interface internal
    VLAN 10
    zone guest
    base port LAN2
    VLAN ID 10
    IP of guest network and DHCP
    on AP go to AP profile SSID tab security make a password for guest
    go to SSID add in profile name the SSID guest password VLAN ID 10
    go to AP management and add guess profile to the WIFI radio
  • Zyxel_Melen
    edited July 2024
    Hi @mike_bt,
    I remember you said your APs are connected directly to the same LAN1 network (ports 4 and 5). Looks like you change these to ports 6 and 7?
    If yes, you can follow @PeterUK's suggestion.
    If they still connect to P4 and P5, you just need to change one setting in the above configuration "the base port from LAN2 to LAN1".
    Zyxel Melen
  • mike_bt
    mike_bt Posts: 8
    I have 2 APs connected to the Zyxel USG110 (Model: NWA5123-AC).
    All steps mentioned by @PeterUK are already done and checked them again.
    The problem is that when a user connects to the Guest SSID, he doesn't get and IP address, just APIPA with no internet.
    how are the AP's powered?
  • mike_bt
    mike_bt Posts: 8
    APs are powered through a PoE switch (acting as dumb switch)
