ATP 500 - static ip, "Enable IP/MAC Binding and DHCP Enforcement" option from instandalone mode
Hi there,
does anyone know, if the above option, when configuring static ip addresses is available in Nebula?
I would need that option, for blocking unwanted devices on the network having generally access and i also wonder if there is any other way to acomplish this?
Many thanks for help
Alexander
Best Answers
Just a limitation of Neubla (in other words not added yet) where as stand alone has this feature.
Hi @AlexandervonW ,
Currently, there is no "IP/MAC Binding and DHCP Enforcement" with ATP/USG FLEX on Nebula mode.
You can use the "Cloud Monitoring Mode" to monitor the APT500 on Nebula and to use "IP/MAC Binding and DHCP Enforcement" on Premise mode as a solution.
Zyxel_Judy
Hi Zyxel_Judy,
ok, thanks. I will look into that. For me, this discussion can be closed.
Have a nice day..
Alexander
Hi @AlexandervonW ,
There is “IP/MAC binding" on the Nebula. To implement that feature, you can follow the steps below:
- Go to Configure > Firewall > Interface Page
- Select the relevant interface and click the Edit button.
- Enable the DHCP server and enter the required information.
- Click the + Add button for the Static DHCP table.
- Create entries in the static DHCP table by specifying the IP address and MAC address for each client.
- Click the OK button.
Zyxel_Judy
Hi Zyxel_Judy,
yes, i know there is IP/MAC binding in Nebula, but is there also "DHCP Enforcement" enabled? Because that means, if i do not use for. ex. a DHCP server on that network, only known MAC addresses can have access to the network?
Thanks for help
Alexander
So have you tried a static IP on the network and it work?
One way to add DHCP only is a switch with DAI (DHCP Snooping) I think
Hi PeterUK,
nice to hear from you again. I used another account with my last problem, the same topic with a new USG FLEX 200H.
No, i did not try that in Neubla, i thought i ask first. As i wrote in my last comment on the USG FLEX 200H topic, i moved back to a ATP500 and there everything is working as it should. (Even the more than one time admin login problem with uOS in macOS is gone, cool!!!)
But back to topic, may i ask why nobody is using this feature? Why should i use something on a switch, if the firewall has this working and easy to configure feature?
best
Alexander
Hi PeterUK,
I thought so, but now you confirmed. Thank you very much.
Have a nice day
Alexander
Hi @AlexandervonW ,
Zyxel_Judy
Hi Zyxel_Judy,
Have a nice day..
Alexander
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
