EX5601-T0 Parental Controls do not work (F/W V5.70(ACDZ.2)C0)
F4RN_Chris
F4RN_Chris Posts: 5 image  Freshman Member
I'm searching for any reference to a known bug / firmware update to fix this
I have an EX5601-T0 F/W V5.70(ACDZ.2)C0
If I select the Parental Control tab in the dashboard I get this screen
Note spelling mistake "Add more Profile" - I'd suggest this should be "Add Profile"
However, if I click on this (either highlighted yellow or the tab) nothing happens.
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    It is recommended that you contact your service provider or retailer for assistance.
  • Liba
    edited July 2024
