SSL Inspection not running well
USG FLEX 200H V1.21(ABWV.0)
Only some sites run well many others load slowly or not at all
Hi @PeterUK,
Could you provide the URL/link you test for us to check? We need the site run well and the load slowly one. Also, it would be helpful if you could share the loading time for comparison.
Zyxel Melen0 -
Hi @PeterUK,
I did a simple local test and the websites "Yahoo UK" and "Home of Gibson Research" are able to load.
Could you help to share these information for investigation?
- The "Server Signed Certificate Key Mode" you used.
- The SSL inspection summary. Below is an example screenshot.
- A video you access those websites, you mentioned above, with a timer.
Thanks in advance.
Zyxel Melen0 -
The Server Signed Certificate Key Mode is the default ecdsa-rsa-2048
I get a video done in VirtualBox
Ok here is the video
Also when I had a license non H Flex200 SSL Inspection worked fine
Other problems are the SSL Inspection is messing with the site code like scan.co.uk
Hi @PeterUK,
Could we schedule a remote session to address this issue? I will direct message you to arrange the timing.
Zyxel Melen0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
