Strange DHCP problem
eGuyane
eGuyane Posts: 7 image  Freshman Member
Hello ;)
I have been experiencing a strange problem with DHCP for a few days.Some computers do not receive an IP address while others receive their IP configuration correctly.Regarding the pool size, everything is in order; I have 50 addresses distributed in a pool of 200 addresses.In the logs of the USG 60W, I have a lot of lines concerning DHCP, but I can't really understand what is happening.I am reaching out to you to try to understand the problem, please.
Thank you in advance
Frantz
  • eGuyane
    Hello
    Thank you,
    thanks to the analysis, we immediately understood where the problem was coming from. There was another DHCP server (172.16.1.1) broadcasting on our network (192.168.0.1). This equipment is not ours and is normally on a dedicated VLAN. We will therefore be able to resolve the issue with the other service provider.
    I thank you for your valuable assistance.
    PeterUK Posts: 4,169 image  Guru Member
    edited July 2024
    Could you run Wireshark on the given PC with filter
    arp or port 67 or port 68
    run cmd
    ipconfig /release
    ipconfig /renew
  • eGuyane
    Hello
    Thank you,
