Assistance with Guest SSID and VLAN Configuration
2»
  • mike_bt
    mike_bt Posts: 8
    You mean by PoE injectors so the APs are directly connected to the physical ports of the USG110?
    PeterUK Posts: 4,264 image  Guru Member
    Yes PoE injectors pass VLAN tags a PoE switch without VLAN support can not
