Zyxel USG20-VPN Enable LAN1 using CLI
Jeff_ATS
Jeff_ATS Posts: 11  Freshman Member
edited July 2024 in Security
I accidently disabled LAN1 on the GUI and I do not have SSl Web Access enabled, what CLI command can I use to enable LAN1?
Best Answers
    PeterUK Posts: 3,740  Guru Member
    I think its
    configure terminal
    interface lan1
    no shutdown
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,176  Zyxel Employee
    edited July 2024 Answer ✓
    Hi @Jeff_ATS,
    You may use show interface all to make sure the interface's name that you disabled and reference @PeterUK's example command to enable.
    For more information about the CLI command, please reference our CLI reference guide:
    https://download.zyxel.com/USG20-VPN/cli_reference_guide/USG20-VPN_V5.37.pdf
    Zyxel Melen
  • Jeff_ATS
    Thank you all! Took a while to get the correct console cable
    Welcome to USGFLEX 50
    Username:admin
    Password:
    Router> show interface all
    No. Name            Status              IP Address      Mask            IP Assignment
    1   wan             100M/Full           xxx.xxx.xxx.xxx   255.255.255.248 Static
    2   sfp             Down                0.0.0.0         0.0.0.0         Static
    3   lan1            Inactive            0.0.0.0         0.0.0.0         Static
    4   lan2            Down                192.168.2.1     255.255.255.0   Static
    5   Classroom       Down                192.168.3.1     255.255.255.0   Static
    6   Chemical        Down                192.168.5.1     255.255.255.0   Static
    Router> configure terminal
    Router(config)#interface lan1
    Router(config-if-lan1)#no shutdown
    Router(config-if-lan1)#exit
    Router(config)#exit
    Router# show interface all
    3   lan1            Up                  192.168.1.251   255.255.255.0   Static
    Router# exit
    Username:
