VTI bootup causes VLAN to fail
PeterUK
PeterUK Posts: 4,446 image  Guru Member
USG FLEX200H V1.21(ABWV.0)
P4 VLAN47192.168.255.39 255.255.255.240
VTI Route-based
IP 192.168.254.9
Pre-Shared Key 12345678
Phase 1 AES128 SH256 DH2
Phase 2 AES128 SH1 DH2
VTI IP 192.168.255.42 255.255.255.240
Nailed-up
On bootup clients onVLAN47 have no internet ping to 1.1.1.1 fails
workaround go to network > interface > advanced setting disable/enable the VTI
Also uptime might be a problem
    Odd testing again its not doing this must of not waited after boot shows good long enough
  • Zyxel_Kay
    Hi @PeterUK
    We would like to check if the issue still occurs.
    If you need further assistance, please let us know.
    Kay
    I think it was a case of the flex shows as ready LAN client gets a IP ping fails for a minute then works
