Limit VPN users
Dylan96
Dylan96 Posts: 35 image  Freshman Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
edited July 2024 in Nebula
What is the best way to restrict access to a user in VPN to a single VLAN?
I’m using an ATP100 on nebula.
    You should be able to do a policy rule for a user from VPN to a VLAN
  • Dylan96
    If I use a security policy, I cannot choose a single VPN user as the source, can i?
    In stand alone you can.
  • Dylan96
    I imagined that on prem there was this option....
    so on nebula i can't do anything?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    Hi @Dylan96 ,
    Currently, there is no feature in Nebula's security policy to restrict a VPN user's access to a single VLAN. However, you can achieve this by adding the users you want to restrict into a group, and then assigning that group in the User field within Nebula's security policy.
    *To create a group, navigate to Site-wide > Configure > Firewall > Firewall settings, and set up the group under Authentication Server and External User Group.
    Zyxel_Judy
    Untitled Image
  • Dylan96
    thank you judy, but I don't have an authentication server, VPN users currently use nebula cloud authentication…
  • Zyxel_Judy
    Hi @Dylan96 ,
    Currently, according to the specifications, customers need to have an external authentication server to implement this feature on the Nebula.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
