Multy M1 Problem after firmware update
I have 3 Multy M1 in my house and after the last firmware update they became completely useless! About a month ago, i installed firmware version V1.00(ABZF.7)C0 and after that every few minutes most of my devices are disconnected from wifi…
Is there any way to install the previous firmware or a newer version in order to stop this problem ?
I have the same configuration at home..
After upgrading my Multy to V1.00(ABZF.7)C0 (weeks ago..) the system became instable…Regular disconnection from ISP, sattellites lost connection to the hub (red light every 10 minutes….) etc… Now I finally managed to downgrade the hub to the V1.00(ABZF.4)C0 version, then upgrade to the latest official build (V1.00(ABZF.6)C0) using the official way. Factory resetted, then downgraded the satellites to V1.00(ABZF.4)C0, then connected back to the hub, they were upgraded automatically to V1.00(ABZF.6)C0 and it seems very stable now. No outage in the last 30 min and this is really a big thing compared to the last weeks!
Hey nagyzee how did you manage to downgrade to the previous firmware? Can you tell me how you did this?
just sent you a private message
I have the same problem: my satelites have version 1.00P7. How could you downgrade it to version 1.00P4 after the factory reset? I cannot find the version P4. I still can only find the version P6…
- 242 Nebula Ideas
- 6.8K Security
- 767 USG FLEX H Series
- 386 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
