NebulaFlex Switch GS1920 Series - V4.80 Patch 1 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 4,035 image  Guru Member
Zyxel Switch GS1920 Series Release Note
July 2024
Firmware Version on all models
(Click Hyperlink to download the firmware directly)
Zyxel GS1920-8HPv2 - V4.80(ABKZ.1)C0
Zyxel GS1920-24v2 - V4.80(ABMH.1)C0
Zyxel GS1920-24HPv2 - V4.80(ABMI.1)C0
Zyxel GS1920-48v2 - V4.80(ABMJ.1)C0
Zyxel GS1920-48HPv2 - V4.80(ABMK.1)C0
New Feature and Enhancements
1. [Nebula] Enhance the cloud auto recovery mechanism to prevent the device from being locked when the connection is unstable.
2. [Standalone] Enhance security by forcing users to change the password after first login.
3. [Standalone] Support Zyxel Private MIB - Hardware Monitor - Power Ethernet - Transceiver
4. [Standalone][Nebula] Enhance security by supporting the ECDSA algorithm in SSH.
5. [Standalone][Nebula] Expand NTP servers from 1 to 3
Bug Fix
C=Cloud mode, S=Standalone mode
Bug fixCS
1. [Vulnerability] Fixed crash issue when receive an unexpected HTTPs request content.VV
2. Fixed switch crash issue caused by receiving LLDP packets with over chassis ID lengths.VV
3. [eITS#230400140] Fixed switch crashed issues that is caused by Nessus version 10.5.1 to scan SSH.VV
4. [eITS#230700521] Fixed crash issue which receiving an unexpected format DHCP packet when device enable DHCP snooping.VV
5. [eITS#230801140] Fixed the crash when enable IPv6 and receiving an IPv6 NA packet.-V
6. [eITS#231201249] Fixed switch may reboot automatically when receiving IPv6 packets.-V
7. [eITS#221201201] Getting logging information that contains special characters causes switch hang.VV
8. [eITS#240500205] Switch hang when click PD "Reset" via Neighbor page-V
9. [eITS#230301533] Fixed reading mib zyxelIpsgInfoTable fail.VV
10. [eITS#230301330] Fixed failing to import certificate while the file size is over 5k-V
11. [eITS#230400154] Fixed failing to delete inactive classifiers even though they are not bound to any policies.-V
12. [eITS#230500677] Fixed timer unexpected goes slowly after lots of STP topology change occur.VV
13. [eITS#230500705][eITS#230901020] Switch sometime disconnect with NCC when DNS Bug fix Nebula Standalone requery find server IP has changed.V-
14. [Forum] Fix incorrect swif0 interface counter in standard IfEntry MIB.VV
15. [eITS#230901020] Switch sometime disconnect with NCC when DNS requery find server IP has changed.V-
16. [eITS#231001888] Fixed fail to add policy rule issue when binding the second classifier containing the same socket range as the first one.-V
17. [eITS#240200888] The switch crashes due to field length limitation when the index button at IPv6 table is clicked.-V
18. [eITS#230801482] Fixed an issue causing the switch to repeatedly switch from standalone mode to cloud mode leading to switch offline.V-
19. [eITS#240301159] IPv6 traffic drop or has high latency due to ACL trap the traffic.VV
20. [eITS#240201138] Fixed an error caused by changing VLAN port settings after adjusting Voice VLAN ID.-V
21. [eITS#240301821] Restore wrong type of configuration without displaying an error message-V
Please refer to the Download Link for more details.
Zyxel Melen
  • StouAdmin
    StouAdmin Posts: 19 image  Freshman Member
    thanks for sharing. it's also working for GS1920-24HP but without the V2 which I don't have.
    was that intended ?
  • Zyxel_Melen
    Hi @StouAdmin,
    GS1920-24HP cannot upgrade with this firmware. In addition, GS1920-24HP has been eol for a while.
    Zyxel Melen
  • StouAdmin
    Hi @Zyxel_Melen
    The fact that the GS1920-24HP is eol - I know, but the fact that the question was:
    — it's ALSO working for GS1920-24HP but without the V2 which I don't have. —
    was that intended ? NO you may answer, but it does :-)
    Upgraded 2 switches with no issues at all.
    Just so you know it.
  • Zyxel_Melen
    Hi @StouAdmin,
    I think your GS1920-24HP is the V2 model. I have tested a local test and find the V1 model cannot use this firmware to upgrade.
    Additionally, only the V2 model has the reset and restore button in the front panel.
    Zyxel Melen
  • StouAdmin
    You are absolutely right. It IS a v2, but I'm surprised it's not visible anywhere on the device, so I had to look up the old invoice, and sure enough, it says V2.
    My mistake for claiming otherwise, but errors happen for humans.
    Thanks for support.
