Where can I find in Nebula Control Center a list with all VLANs used in my site?
Best Answers
Hi @lrb24
For switches in Nebula mode, VLAN configuration differs from standalone mode. There's no need to create VLANs beforehand; you can directly assign VLANs to ports. To view which VLANs are allowed on each port, go to Site-wide > Configure > Switches > Switch Ports and add the "Allowed VLAN" parameter to the table.
Kay
Hi @lrb24
Just to provide you with some additional information: although the VLAN list doesn't appear in the Nebula interface, you can check the VLANs on your switch another way. Try using 💎 Remote SSH with Nebula Live Tools. Once you access the CLI via Remote SSH, use the command
show vlanto display all the VLANs configured on the switch.Hope this information helps!
Kay
Hi @lrb24
Kay
Hi @lrb24
Kay
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
