After upgrading Frimware to V1.00(ABMV.6)C0 my wifi 5ghz band not showing.
shishir
shishir Posts: 1 image  Freshman Member
After upgrading Frimware to V1.00(ABMV.6)C0 my wifi 5ghz band not showing. Channel, Channel width in auto mode. Still nothing.
Does it fix if i downgrade the version? Can anyone provide me the old version of the firmware? Or how can i fix it? Please help!!!
MODEL: NBG6615
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @shishir,
    I would like to clarify with you:
    1. Have you used a different device but still not found the wifi 5ghz band?
    2. Have you fixed the channel in band 1 but still not found the wifi 5ghz band?
    Thanks in advance.
    Zyxel Melen
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited August 2024
    Hi @shishir
    according to the release notes, the default 5g channel is 149 in NA(US), so you might need to change this as @Zyxel_Melen asks if your wireless devices cannot pick up the 5g signal, see below:
    Kind regards,
    Tony
