Configure NAT to point public ip to internal ip
HyungKim0105
HyungKim0105 Posts: 10 image  Freshman Member
Zyxel Certified Network Administrator - Security First Comment
I configured NAT and security policy following the guide here and cant seem to connect to the internal server.
Mapping Type:Virtual Server - Interface:Wan1 - Source IP: any - External IP:Wan1_IP - Internal IP: *Points to internal IP - protocol:TCP - external Port: HTTPS - Internal Port:HTTPS
Policy Control:
From:Wan - To:Lan1 - IPv4 Source:any - IPv4 Destination:*Points to internal IP - Service:HTTPS - Device:any - User:any - Action:allow
also its 1 on priority.
anything I might be overlooking?
any help would be greatly appreciated! thank you!
    PeterUK Posts: 4,264 image  Guru Member
    Is the USG behind another NAT router?
    packet capture WAN interface as you scan for port 443 on GRC from IP 4.79.142.206
    GRC | ShieldsUP! — Internet Vulnerability Profiling
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @HyungKim0105 ,
    It seems you cannot access your internal network from the internet. Please correct me if I'm misunderstanding your question.
    To better assist you, could you provide the following information:
    • The Zyxel model you are using
    • The network topology
    • A screenshot of your configuration
    Zyxel_Judy
    Untitled Image
