After upgrading Frimware to V1.00(ABMV.6)C0 my wifi 5ghz band not showing.
shishir
in Home Router
After upgrading Frimware to V1.00(ABMV.6)C0 my wifi 5ghz band not showing. Channel, Channel width in auto mode. Still nothing.
Does it fix if i downgrade the version? Can anyone provide me the old version of the firmware? Or how can i fix it? Please help!!!
MODEL: NBG6615
Hi @shishir,
I would like to clarify with you:
- Have you used a different device but still not found the wifi 5ghz band?
- Have you fixed the channel in band 1 but still not found the wifi 5ghz band?
Thanks in advance.
Zyxel Melen0 -
Hi @shishir
according to the release notes, the default 5g channel is 149 in NA(US), so you might need to change this as @Zyxel_Melen asks if your wireless devices cannot pick up the 5g signal, see below:
Kind regards,
Tony
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
