Smart Mesh, Wifi 7 and Backhaul, how does this work?
jj38100
jj38100 Posts: 10 image  Freshman Member
edited August 2024 in Nebula
Will the Smart Mesh backhaul take advantage of Wifi 7, specifically MLO feature sets as well. I'm still waiting on my second WBE130 to be delivered, but I am curious.
Also, will that be reflected in Nebula on what the Backhaul is doing?
Best Answers
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279 image  Guru Member
    Hi @jj38100
    Currenlty, the MLO feature on our Nebula WiFi 7 access point is only take advantage to the WiFi 7 clients(ex: PC, mobile devices, and etc.) but not the mesh connection between access points.
    Could you please share more details on the specific information you are looking for?
    Kay
  • Zyxel_Kay
    Hi @jj38100
    Thank you for your input.
    I agree that implementing the MLO feature in the Smart Mesh function would significantly enhance performance.
    Regarding your suggestion, I've created an idea post here:
    If you support this idea, please feel free to vote and comment. Votes and comments will be considered when evaluating this feature request.
    Kay
  • Zyxel_Kay
    Hi @jj38100
    Kay
  • jj38100
    edited August 2024
    That answers my question, Wifi7 MLO isn't used for the back haul so that answers my question
    I guess if you can clarify, is Wifi 7 used at all for the back haul? So like QAM stuff would help with increased throughout
    Thank you!
  • Zyxel_Kay
    Hi @jj38100
    Kay
Nebula Tips & Tricks
