Flex 700H reboots and issue
Hy team.
I'm having serious issue with two 700H firmware 1.10(ABZI.1).
One of them had to go out of production and I had to buy a Flex700 and the problems were gone.
I have random reboots and system crashes.
One of the issue is that it seems that the device works but it does not assign DHCP and you cannot access it. I set a static IP and I can't access it via GUI. In console I can ping all interfaces, but the firewall is still blocked. Restarting solves the problem.
Another issue. Sometimes, when I connect a Zyxel 1 meter DAC or other DAC cable to the SFP+ module it restarts automatically. This is a problem because my ISP works with SFP+.
I have a video where the error appears.
With a cable in the console the error does not appear, it just restarts.
Another issue is that I cannot use any Transceiver because my 700H cannot work with them.
Another issue is that through SFP+ and DAC between switches is not correct. The vlan assignment is incorrect. By switching to copper the problems were solved.
I think the problems are in the SFP+ module
Since October it has been one problem after another....
I have tried to open support tickets but I have no response from Zyxel and I am desperate.
I have a 700H in a box and the licenses are running and another one in production that the customer is starting to get angry.
I need help, urgently....
Its a whole new OS so problems are going to happen I guess the SFP+ module where not tested all that well sadly...
as a workaround for your ISP by SFP+
https://www.amazon.co.uk/10Gtek-Ethernet-Converter-1000Base-Tx-Transceiver/dp/B01MG48FD5/ref=sr_1_9
Peter, it's what I do but this cooper makes me lose internet packages. The router is an Accedian and it is special. Just like Cisco.
Good day together
I now also have a 700H which I wanted to connect to an XGS1930-52HP via Zyxel DAC 1m SFP+ cable. The DHCP works correctly on all three VLANs. But I can't get access to the WAN and the firewall itself. Is this a setting of mine, or still a bug?
Best regards
Niklas0 -
The SPF+ is still an issue/bug - especially with firmware 1.20. I'm using port 13 with a Zyxel SFP+ transciever as LAN connection to our XGS1930. I had to downgrade from 1.20P0 and 1.20P1 to a 1.10P1 beta firmware to make it stable. Zyxel Tech are working on ours to hopefully fix it.
I have the same problem. The SPF+ has an bug. The DHCP works not at a new start.
Run arp -a from a command prompt - copy the mac address of your gateway. In your H series firewall go to Network>Interface>the interface of your SFP+ (ge3) - select Overwrite Default MAC Address and insert the copied MAC address from the command prompt.
That should do a workaround to the bug
It does not work. After reboot the switch (and all other switches/Access Points) behind the firewall on SFP+ Port lost the connection to the nebula cloud. Only the short unplugging of the cable connects new to nebula
That fixed it on our 700H - are you using the SPF+ for external or internal interface? What firmware level are you on?
Hallo, firmware level is the latest: v1.21and the SPF+ is a internal port.
Can you try setting the negotiation to 10GB and not Auto?
- 414 Beta Program
- 2.3K Nebula
- 132 Nebula Ideas
- 92 Nebula Status and Incidents
- 5.4K Security
- 183 USG FLEX H Series
- 258 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 37 Wireless Ideas
- 6.2K Consumer Product
- 237 Service & License
- 374 News and Release
- 79 Security Advisories
- 24 Education Center
- 2.9K FAQ
- 80 About Community
- 69 Security Highlight
